Anyone know the thread size of the 2 original bolts that hold the power antenna bracket to the plate with the weld nuts? I had to drill out the broken bolts and want to tap the correct size back into the weld nuts.
'66 power antenna bracket bolt thread size
Re: '66 power antenna bracket bolt thread size
Rob -- pulled the top P.Ant mount bracket bolt off my '65 for this pic (was working in the general area anyway). It's a 1/4" diameter (7/16 indented head bolt) with a captive lock washer. Overall length is 0.915", and you can count the threads [which are 28 threads/inch pattern].
Attached Files- Top
