'66 Headlight Motor Question
  • Phil B.
    • Today
    Hi All, Having trouble with one of my headlight motors. Testing it off the car. Sometimes it appears to work fine. Other times spins freely at good speed and then with no load stops. Try to restart nothing happens. Hook up power to other side. Nothing. Wait a minute or so spins until it binds again. Everything was cleaned and looks good including brushes. Any recommendations or trouble shooting steps. Thanks.
  • Wayne W.
    • May 1, 1982
    • 3605
    Re: '66 Headlight Motor Question
    May be kicking the thermal switch. It aint made to be a continously operating motor.
    • Phil B.
      • Today
      How can I test this switch?
      • Jack H.
        • April 1, 1990
        • 9893
        The thermal overload switch isn't meant to be tested! It's a Federal safety requirement for electric motors and the 'feature' is built into the motor to prevent fire/melt-down in the event of severe overload.
        • Craig S.
          • July 1, 1997
          • 2471
          It is inside the motor near the brushes. It may also have dirty points, take an ign points file and clean the contacts, and make sure the bimetal spring is applying solid pressure to the points...Craig
