Warning: Undefined array key 5516 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
'66 Headlight Motor Question -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Hi All, Having trouble with one of my headlight motors. Testing it off the car. Sometimes it appears to work fine. Other times spins freely at good speed and then with no load stops. Try to restart nothing happens. Hook up power to other side. Nothing. Wait a minute or so spins until it binds again. Everything was cleaned and looks good including brushes. Any recommendations or trouble shooting steps. Thanks.
The thermal overload switch isn't meant to be tested! It's a Federal safety requirement for electric motors and the 'feature' is built into the motor to prevent fire/melt-down in the event of severe overload.
It is inside the motor near the brushes. It may also have dirty points, take an ign points file and clean the contacts, and make sure the bimetal spring is applying solid pressure to the points...Craig
