...On my Carvette, B&M Electric Trans Temp Gauge indicates about 100* after quite a few miles of normal warm up. So, should I be concerned it's too low, or should I be a happy camper and just wear a happy face...??? TIA, Dennis
Off Subject: THM400 Oil Temp Question...
Re: Off Subject: THM400 Oil Temp Question...
Sounds good to me! 100deg. is pretty cool for an autobox to run. Normal temps are closer to 180-200F, but...cooler is always better for a trans. Ya sure the gauge is accurate?!
Attached FilesJoel Adams
1974 Coupe
1985 Coupe
"I know the voices aren't real...but sometimes they have some really kewl ideas...."
- Top
Dennis------
I'd check the gauging system for accuracy. All THM-400 used a transmission oil cooler of one sort or another, but I don't think that very many, if any, would run as low as 100 degrees under normal operating conditions and ambient temps.
By the way, you're not necessarily "off-subject". Quite a few Corvettes originally used THM-400 transmissions which was one of the best transmissions ever installed in a GM car. It was so good that after, essentially, discontinuing it in the 80's, GM brought it back and, even later, updated it to electronic control.In Appreciation of John Hinckley- Top
Or when I used my wife's dishwasher
to clean a really nasty, flea market bell housing? I washed it twice and then ran the dishwasher twice with nothing in it to clean the dirt and grease. I don't believe that I have mentioned this yet to her.
Gary
btw, I highly recommend dishwashers to clean parts, provided you have spousal approval. Worked like a champ.- Top
Re: Or when I used my wife's dishwasher
The dish washer does an incredible job on wiring harnesses too.....- Top
LOL!!! Whadda you guys use ta warsh yer dishes? Take 'em to da car warsh?!!LOL
1974 Coupe
1985 Coupe
- Top
Oh, that? For that, I use the regular dish washer. The regular dish washer has been doing the dishes for a few years now and she does a pretty good job.- Top
