Warning: Undefined array key 5516 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
Gold Line Tires.....65' Corvette -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Has anyone seen the NEW Coker, Gold Line "Super Sport" bias ply tire??
Is it "correct" for NCRS judgeing? I went to Coker today and they "claim"
that they are 100% "correct" and will pass the test!!
Also....
I am looking for an original power antenna for my 65'.
Mine has been bent and I would like to have another on hand. Any info would be appreciated. I do not want a reproduction.
Yes, the Super Sports are available without DOT markings. They are sold as "show only" and not for street use, in order for them to be sold legally. I have not closely examined the Super Sports repro, but others that have stated that there are differences. The Goodyear goldlines are more accurate but have the DOT marking. So you will likely take a small deduction either way. That is unless you do some careful surgery to remove the DOT markings from the Goodyear
I have an original Super Sports spare tire for comparison.
--------A bunch of us looked at those Super Sports at Carlisle last year and couldnt believe that Coker was claiming that these tires were exact duplicates. Closer to the originals than before,,,,maybe! Put an original next to thier tire and the 100% claim falls apart quickly. The construction appeared to be way different. Its the details that count and we didnt feel that they had the details down at all.........Bill S
OEM Glass in IL. for original power Antenna's. Without a core expect around $700. They only do complete rebuilts for around $525 meaning they sell no parts such as cable.
It doesn't cost a dime more to make the molds "correct"; you have to wonder why they make the investment in new molds and don't bother to consult with someone who knows what the real thing looks like in order to make sure the product is indeed "judging-correct" to ensure a solid marketing position. Maybe the same guy did that one that does their "orange" goldlines.
