LS-5 - NCRS Discussion Boards
LS-5
  • lyndon sharpton
    LS-5
    on the heater control valve, can you get at it with the side panel off? also the hose that goes to it does it have a white stripe on it? 71 LS-5
    Re: LS-5
    Yes, access to hot water shut-off valve is via fender's side panel 'egg crate' grille AND vac control hose is black with white stripe.
    • lyndon sharpton
      Thanks Jack *NM*
