I am having a hard time keeping my PS belt tight on my car. it is a LS-5 with AC. I can get it tight then drive it a short time an then it is lose again. any thoughts
PS belt LS-5 71
Re: PS belt LS-5 71
lyndon-----
How tight is "tight"? Are you sure that you have the bolt tightened to the specified toque spec. Sometimes, bolts that are hard to get at don't get tightened sufficiently.
Second, if the power steering pump is moving and relaxing tension on the drive belt, then that may also cause loosening of the generator drive belt. Is the generator drive belt loosening, too.
Lastly, are you using GM SERVICE belts? I've found them to be, functionally, the best. For your application, I believe the belt should be a GM #9433739 which is 7/16 X 43-1/2" long or a a GM #9433738 which is 7/16 X 43" long. I'm not sure which and GM is no help on this one. The original belt was of GM #3940992 which was a 15/32" X 43-1/2" belt. However, a 15/32" wide belt, which have not been available from GM in years, will ride a little higher in the pullies than a 7/16 wide belt. So, the slightly shorter 43" belt may be required. Both of the SERVICE belts mentioned remain available from GM.In Appreciation of John Hinckley- Top
similar problem on my '70 BB
Several things come to mind.
A new V belt seems to loosen up during it's initial use as it tends to settle deeper into the groove on the pulley. On my car (BB, AC, PS) the "correct" belt would go on fine, but after settling in, was apparently "too long" as even with the PS moved out as far as it would go, would not have adequate tension. I had to start with a belt that was about 1/2" "too short" - a pain to muscle onto the pulley the first time, but once settled into place would maintain correct tension. (sorry, don't remember the length)
Make sure to get all the pump mounting bolts fully tightened - I had to really contort my arms to do that (now I know why the dealership mechanics hated Corvettes .
Use a name brand belt, I think they tend not to loosen up as much.
Mark- Top
