confussed on engine removal - NCRS Discussion Boards
  • Ken Bushley
    I have a 1975 and I want to remove the engine to rebuild it. I thought that i would pull the tranny before i did the motor. I went under the car yesterday and it looks like the whole thing has to come out as one unit..Is this correct? I thought i could remove the tranny but looking at it i am not sure if it is possible.The cross menber is the welded type and it just seems like there will not be enough room to get the tranny out. Help
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: confussed on engine removal
    Ken
    You must have a 4 Speed and if you do it will come out with no problem. This is the best way if you have no need to remove the radiator.
    Lyle
    Lyle
    • Jim T.
      • March 1, 1993
      • 5351
      I have removed my 68's 4-speed a couple times since it was new and it has the same welded crossmember.
      • Nick K.
        • December 1, 1999
        • 75
        You'll have to remove the hood, radiator, shroud etc... then pull the enigne and trans out together.
        Nick #33307
        Nick Kammer, #33307
        Chairman
        Miami Valley Chapter (Dayton, Ohio)
        937-602-8829
