My engine rebuilder thinks the cam must have been replaced along with the timing gears, it looks new. He recomends keeping it since it shows no wear at all. It may have been the last thing done to the engen befor the car was parked for 13 years. The question is, is this a correct or a replacment cam for a 63? It has the following numbers GM-28 6930 and a date code E31. There is also a dimond between one set of lobes. There is no other signs of the engine being worked on. All of the valves pistons and bearings look original.
Thanks Carl
Thanks Carl
