My '66 L79 has its' original (and I think unrebuilt) ..320 starter. After turning off the engine, with hot outside temperature, it sometimes struggles to turn the engine over when I go to restart it. What exactly should I look for in a rebuild kit, in an effort to fix the problem, and where might I find one. So far, I haven't found anyone in my area (S CAL) that carries one. I've been calling around looking for new bearings and brushes and haven't had any success.
'66 orig small block starter rebuild
Re: '66 orig small block starter rebuild
You will need a new set of bushings for the drive end and the communtator end plus a set of brushes. Take emory cloth and polish the communtator on the armature. You may have to undercut the insulators on the communtator slightly. If you do I have found a broked hacksaw blade does a very good job.
The Carquest numbers on the parts are
RX60 Brushes
X4349 Front Bushing .720 long
X4356 Front Bushing .500 long
X4378 Rear Starter Bushing
I am not sure which bushing that you need for the front, but at under $3.25 each, it would not hurt to order both.Dick Whittington- Top
Re: ADDENDUM....
Rob-----
1) Just about any starter that you purchase rebuilt for your application will be a Delco and it will have parts interchangeable with those in your starter;
2) Most of the parts that might be required in a rebuild are available from GM:
brush (4 required)------GM #1906495
frame, commutator end with bushing------GM #1974157
bushing, drive end-----GM #1923907
drive--------GM #10470757
3) Aftermarket kits are available; I've seen these in auto parts stores. I don't recall the brand name;
4) Generally speaking, even if you rebuild the starter with all new parts for the commonly replaced items (described above), I think that you're still going to have the same problem. However, it's worth a try. These parts are not too expensive.In Appreciation of John Hinckley- Top
Re: ADDENDUM....
Joe,
Assuming the problem I described is a result of high compression and hot temperature, what would fix the problem? The starter functions fine under normal conditions and only labors on occasion under the conditions described.- Top
Re: ADDENDUM....
Rob------
I fought this same problem for years once-upon-a-time. I tried EVERYTHING to cure it. The only solution that was 100% successful was the installation of a remote (slave) solenoid.In Appreciation of John Hinckley- Top
Hi Rob.
Just my 2 cents. I have a 56 chevy 350 semi-built engine. I was having the same problem.After driving awhile and then shutting off hot engine, it would drag when I tried to start it again. I solved my problem with a larger diameter battery cable. It cranks and starts quicker. Check your cables and maybe try replacing the positive cable and see if that helps. I know it help me.
Good luck.......John- Top
