The tire monitoring system on my 2001 corvette coupe says that the left rear tire is flat and i put a new tire pressure sensor in the wheel as i thought that was the problem. The car still tells on the display center that the tire is flat. I wouldnt have a problem with this except that the car beeps every ten minutes to tell me the tire is flat...and its obviously not. I have referred to my service manuals for further help but i have not been able to resolve the problem. If anyone has any suggestions for me they would be greatly appreciated. Thanks in advance.
C5 2001 TIRE MONITORING SYSTEM PROBLEM
Re: C5 2001 TIRE MONITORING SYSTEM PROBLEM
What pressure is it telling you? Or is it just registering low?
And when you go check your tire pressures, what are they at?
PatrickVice-Chairman (West), Michigan Chapter NCRS
I tried using the magnet like you suggested. When i put the magnet up to the other three wheels the horn honked as described in the manual. However the wheel that has the problem did not honk the horn and the system still reads the tire as being flat. Anymore suggestions? Thanks.- Top
