A long time back (probably nearly two years ago!) I posted on this board in an attempt to find out about the correct alternator for my 80 L48. At the time, more important issues came up with the car and I kinda left the trail to go cold, but I'm back to it now.
I've recently installed electric fans and the (incorrect, 63A) alternator is struggling to keep up when the lights are on.
I know my vette should have had the 70A alternator, as it is optioned on the build sheet (K30? - might be quoting the wrong number from my memory!)
My present plan is to try and find a correct # 70A unit, with a view to upgrading the rotor/stator/internals to a higher output. I realise this may be problematic with regard to heat issues, and if it proves to be a problem I'll just have to go for a non-standard, hi-output one. You might wonder why I'm so fussy about originality if I've just put in very non-standard elec fans, but although I'm not religious about originality I'd like to retain it where I have the choice.
What I need to find out, so I can see if this is a feasible plan, is what series alternator this 70A unit would have been. I've picked up all sorts of conflicting views in my web search, but the last definitive info I got from this board was that it should be a delco 12-SI unit (thanks to Joe Lucia!!) However, my more recent "digging" at the delco part catalog site has suggested that it should in fact be a 15-SI. I need to find this out before I can assess if there's any potential for upgrading it, if and when I find one.
So, Joe, if you read this, am I being fed BS about all this 10/12/15 SI stuff? I'm not suggesting for one minute that you gave me the wrong info back then, I'm just confused as hell because you would hope that the delco online catalog would be at least fairly accurate!
Thanks all, in advance.
Theo
Theo
