Ok...a little bit of knowledge is dangerous, but is there any advantage of one over the other for a SB. I have read the Cometic is "reusable" which in my case may work out since I may use it first for the deck plate when honing my block. I also like the wide availability of thicknesses to enable dialing in of static compression ratios. Yes..I know the Cometics are more $$$$ but just reusing em once for the deck plate hone will justify the difference.
The Fel-pro 1003 has very positive feedback but anecdotally, I did have a leaker on my last motor. I went back to the steel shim and had no problem.
Thanks..
Thanks..
