I've read through the chassis service manual and walked through all the adjustments. I still have a problem--it is this:
The window is adjusted fine--right height, angle, etc. When I roll it down, and then roll it back up, it binds in the front when it is about 3/4 of the way up. I can, at that point in time, take the entire window and it will slide back 1 1/2 to 2", which then allows it to roll up the rest of the way, and be positioned correctly.
Looking insed the door, I can't detect anything amiss--but something obviously is. I have no frame of reference other than the other door/window, but have not yet pulled that door panel to try to figure out the difference.
What am I not doing right or missing?
Thanks for you help!
