I have an aftermarket cam in my 435 hp. 67,which is more radical than the stock 435 cam.The one speck I am positive about the cam is it has 7" of vacuum at idle.All cooling items,radiator,waterpump,fan clutch, are new.The car runs at 180 degrees on the road.I think the 435 advance can is not working with just 7" of vacuum,causing overheating at idle.Does anyone know how much vacuum the 435 needs at idle? What vacuum advance can should I try to solve this problem?
Thanks Al
Thanks Al
