Years ago, a friend gave me a vacuum pump and a set of guages for an R-12 system. I used them, then and now I am not so sure as how to hook them up, and use them. I have the red hose hooked up to the port / line that goes to the condenser/dryer. The other to the line from the POA valve. With the car off, they both read 56. It holds steady at that. With the engine on, A/C on, the blue valve reads 6#psi and 7 on the r-12 field. The red valve reads 56# psi and 60 on the r-12 feild. The car doesn't cool as well as last few years and I think it is low on r-12. I do remember how to use the vacuum pump and I think I remember how to add r-12. I have a 71 SB and the original compressor. Could someone please help me walk thru this. I have the 71 service chassie manual an a A/C straregies book, which are really, no help at all.
Chasman
Chasman
