'64 Expansion Tank Cap - NCRS Discussion Boards
  • Gregory G.
    • July 31, 2001
    • 203
    Which is the correct version of the 307 #13 expansion cap.With a circle encompassing these numbers or without the circle?
    The numbers are located at the nine o'clock position as you read it from left to right.
    Greg
  • Charles R.
    • April 30, 2006
    • 13
    Re: '64 Expansion Tank Cap
    Look at spring '79 Restorer - Circle caps were used 8/63 to 3/66
    • Peter L.
      • May 31, 1983
      • 1930
      Greg - I don't think any of the original 307 radiator cap had a circle emcompassing the numbers. Don't have one with me but hopefully someone will provide info on the configuration of the lettering on the cap. Pete
      • Gregory G.
        • July 31, 2001
        • 203
        Pete,
        LIC sells a repro without a circle.
        Dewitt sells one that he fabricates with a circle.
        Who is correct?
        Pircle believes it should be without the circle.
        Greg
          • 11608
          FYI, DeWitts does not manufacture reproduction radiator caps. He may sell them, but does not make them.
          For various reasons I would think the LICS one is a more correct configuration.
          Patrick
          • Alan Drake
            My Mar 64 FI cap has NO circle!
            Have owned since Aug 67 with
            • Peter L.
              • May 31, 1983
              • 1930
              Greg - Check out the picture of an original 307 radiator cap on Ebay Item 4635644307. The only variation in the caps I am aware of is that the AC stamping came in a larger and smaller AC. Not aware of original 307s having the AC in a circle. From what I have seen the AC logo in the circle did not come in to use until the 1966 RC15 radiator caps. Pete
              • Mike L.
                • January 1, 1986
                • 312
                No circle on cap!!!
                • Alan Drake
                  I'm talking about no circle around the 307/15# markings.
                  Just wanted to be clear in case that's not the circle you are looking at/for.
                  NOT about the AC logo. Check the TIM/JG to see what's called for and follow that.
