C2 300hp Rebuild...estimates parts&labor - NCRS Discussion Boards
  • Jim V.
    • November 1, 1991
    • 587
    After a fair amount of reseach and a lot of help from fellow posters (JoeL, Duke, Clem, et.el.) I have pieced together the following estimates for my street rebuild. The objective is a durable 1965 low-rev 300hp street motor. Please feel free to comment....
    ............................Parts................. ..........................
    Freeze Plugs
    Paragon (no logo)
    Cam Bearings
    Dura-bond CHP-8 $20
    Cam
    GM 14088839 ($22 from Sallee Chev)
    Pistons/pins
    KB156 $214 (Gap .028/.017)
    H660CP FM $176
    Rings
    Sealed Power E251K020 $36
    FM Speed Pro Perfect Circle Moly #R9903 $$$$
    Total Seal Moly #9090
    Lifters
    GM 5232720 $90
    Sealed Power HT-817 $40
    HT-817R (hi rev) $60
    Push Rods
    GM 12495491 $43
    PR5015R $16
    RP3212R $64 moly hardened
    Valves
    Manley Street Flow $140
    Manley Budg. Perf. $90
    Sealed Power V1199 1.5" $40
    Sealed Power V1926 1.94" $40
    Guides
    K-line thin wall bronze
    Cast Iron
    Seals
    Viton Umbrella
    Retainers/Keepers
    Springs
    GM 3911068 $89
    GM 14003974 $39
    GM 3735381 (orig) $98
    Timing chain
    Cloyes #9-3100 $60
    Oil Pump/Drive shaft
    Melling M55 $15
    Main/rod Bearings
    FM 994M $54
    SP 2020CP $48
    Gaskets
    Head FP #1003
    Intake Paragon 930K
    Oil Pan FP #OS 34509T
    Valve Covers FP #1604
    Other
    Rod Bolts
    ARP 11/32 134-6001 $53
    .................................Machine Shop Labor..........................
    Heads- Valve job and guides $350
    Block- Bore/hone $300
    Rotating Assy- recond rods/crank/flywheel and bal $600
  • Verle R.
    • March 1, 1989
    • 1163
    Re: C2 300hp Rebuild...estimates parts&labor
    Any labor/machining estimate is dependant on local costs and vary greatly from one location to another.
    Parts cost depend on vendor and brand name.
    My estimate to do a 327 would probably be a lot different, example:
    local cost to vat, bore and hone is about $200.
    turn crank $150
    balance $100
    These are costs at a high quality machine shop.
    Verle
