57 Intake Manifold - NCRS Discussion Boards
57 Intake Manifold
  • Michael K.
    • August 31, 2004
    • 170
    57 Intake Manifold
    Does anyone have any experience at installing the exhaust block off plates for the intake manifold? They come four in a set, and I am told that you should use one on each side of the gasket. When installed by the gasket manufacturer, they are tack welded together. What would I use to hold them together during installation? I thought about using a small amount of silicone, clamping the two pieces together, and letting it dry overnight. Once the manifold is installed, they shouldn't move or seperate. Your thoughts and suggestions are appreciated!
  • Clem Z.
    • January 1, 2006
    • 9427
    that will work
    as the manifold will hold them after it is installed
