C-1; Steering Wheel for the beer belly... - NCRS Discussion Boards
  • Isaac Tyson
    Well, I've heard people talk about how large the C-1 wheels are and how they just can't fit that beer belly past the wheel. So, I have come up with a quick fix! All you do it cut the wheel in half just below the spokes! Then, place the two half at a 90 deg. angle from each other and get out that welder to weld it back together! Check out mine in the picture! Now, if that doesn't look good I don't know what does! And now you have the extra room for the big belly! So, no more crying about being too fat and not being able to drive your Corvette! Just cut that wheel in half!
    Ok, ok. So it's just a joke... Actually I had to cut the wheel in half and re-weld it to bring it back to it's correct shape. I also had to cut the spoke because it was bent really bad too. Anyhow, just thought I'd share the fun and give you all some new ideas to move outside the box.
    -Isaac Tyson #45762
  • Dennis B.
    • May 31, 2004
    • 174
    Re: C-1; Steering Wheel for the beer belly...
    Don't dismiss your idea too soon. I think you are on to something. How about attaching the lower half back to the top half using a heavy spring on both sides? It would sort of be like Sansabelt slacks with the flexible waistband.
