power steering problem - NCRS Discussion Boards
  • terry speth
    I installed power steering on my 67. When I started the engine the steering took off in one direction when it hit the limit it took off in the other direction. It will sit there and cycle back and forth. Any suggestions. Terry
  • Gary Schisler
    Re: power steering problem
    Your control valve needs to be balanced.
    Do you have the 67 GM Service Manual? The power steering control valve balancing procedure is in it. In fact, I would guess that this procedure is in all of the 63-82 manuals. Takes about 15 minutes to do.
    Gary
    • Wayne W.
      • April 30, 1982
      • 3605
      Nope, The lines are crossed, or not crossed in this case.
      • Chas Henderson #28127
        Lines crossed or not, unhook the ram. Switch hoses or adjust the valve, then rehook the ram up.
        Chasman
