Brake Fluid - NCRS Discussion Boards
Brake Fluid
  • Jack Corso
    Brake Fluid
    I have a 67 coupe that has a leak from the master cylinder. I had the car for 3 years. How can I tell if it has silicone brake fluid or not? Is there harm in replenishing silicone with Dot 5 or Dot 4 with Silicone. All help is appreciated.
  • Jerry Clark
    Re: Brake Fluid
    Hi Jack:
    Take a capful of the fluid from the master cylinder, put it in a clear glass with a couple ounces of water, silicone and water will not mix. As for your other question, I am not clear what you are asking, if you intend to mix silicone with Glycol, DON'T.
    jerry
