date coe on rochester 7029202 - NCRS Discussion Boards
  • Ralph A.
    • May 31, 2002
    • 236
    I read the date code is on the base. Is this it. Looks like 68 but what date.
    Ralph
    Ralph Adams
    NCRS: 38137 LA: 112
    Slidell, LA 70461
    1969 350/300 LeMans Blue Conv (restoring)
    1971 350/270 Bridgehampton Blue Conv (top flight)
    1972 350/200 War Bonnet Yellow Conv (restoring)
    2001 Bowling Green Metallic Conv (fun car)
    • 15573
    Re: date coe on rochester 7029202
    Would the 230th day of 1968 work? I don't have my charts wioth me, but that would be sometime in the fall I think.
    • Ralph A.
      • May 31, 2002
      • 236
      Re: date code on rochester 7029202
      Did not know if the zero after the 3 was a zero or a C. 1st one I have seen with a date code on the base.
      Thanks but I am looking for a late 69 so it will not work for me.
      Ralph
      Ralph Adams
      NCRS: 38137 LA: 112
      Slidell, LA 70461
        • 15573
        If the carburetor was built by Rochester then the numbers are likely a Julian date, and the numbers I quoted are what you should find.
        If Carter built it, under license to Rochester, then the month designator is a letter (A = January, B = February, ect.) and the year would show 68. As far as I know those are the two options.
        If you are looking for a late 1969 Q-jet the code will be on the body of the carburetor -- NOT the base. The base stamping was another of those 1968 only kinds of details.
        • Clem Z.
          • January 1, 2006
          • 9427
          i have a 7042202 carb here
          made by carter and the base plate is stamped 116 with a 9. has the base plate been changed?
          • Clem Z.
            • January 1, 2006
            • 9427
            PS the body is stamped D2 DJ *NM*
              • 15573
              Re: PS the body is stamped D2 DJ
              Clem -- the D2 is what I would expect from a Carter built Q-Jet. I can't tell you about the base.
