Dual Fours fuel pump outlet line? 1957 - NCRS Discussion Boards
  • Chris Shanahan
    If I look straight down at my fuel pump from the passenger side of the car, my outlet hole to the carb is at 4 o'clock. What fuel line, for what year Corvette will fit and work with this fuel pump? Going to stock 1958 2x4's?
  • dennis frey
    Re: Dual Fours fuel pump outlet line? 1957
    hi chris. i dont know if stock 58 is any different than stock 57 but i can tell you what my stock 57 two 4s is. looking down from the top, inlet is at 9 o clock and outlet is at 3. im pretty sure this is correct as i ordered and installed pre bent stainless fuel lines and thats the way that output line fit correctly. it is any easy proposition to remove all those base screws and rotate the base to put the outlets in the correct position, etc. god luck. d.
