C3 72 TCS Solinoid
  • Rob Cetrone (42529)
    • September 1, 2004
    • 144
    #1
    C3 72 TCS Solinoid
    Hi,
    Could some one post a picture of the tcs solinoid with the foam or spongy thing on it.
    Thank You,
    Rob
  • Patrick Hulst (16386)
    • 11372
    Re: C3 72 TCS Solinoid
    Rob,
    I just bought a piece of black foam from AutoZone that was supposed to be some sort of PCV type filter for whatever. They have a display of them. I cut it down to about the right size, made a hole going half way into it and glued it on.
    Sorry but this pic is the best I have on hand right now.
    Patrick
    • Lyle Chamberlain (24961)
      • September 1, 1994
      • 3228
      Rob
      I have seen two types of filters. One is a square piece of foam 3/8 X 3/8 x 1/2 with a hole in the square end and could be smaller. Should be black or gray and hole can be put in with a hot pencil soldering iron. The second type has an extra plastic part that fits over the end of the solinoid and the filter fits in the plastic. I have seen the plastic part on many different corvettes with no reason I know of why as the stamped part number has been the same.
      JMHO Lyle
      Lyle
