WCFB stall...calling Roy Braatz for advice.. - NCRS Discussion Boards
  • Mark B.
    • February 1, 2004
    • 138
    Roy, if you're on here, I need some assistance. I have searched the archives and found your bushing fix for the WCFB 4-BBL carbs I have on my 59. However, the Borg Warner web site no longer recognizes the part no. 10039B as a good part number. Is there a remedy using either new part nos. or off-the-shelf parts that a carb guy can fabricate? Thanks in advance for your help.
  • Clem Z.
    • January 1, 2006
    • 9427
    most rebuild kits have this piece of tubing
    most model airplane shops carry brass tubing in all sizes BUT i do not remember what diameter you need
    • Roy B.
      • February 1, 1975
      • 7044
      Re: WCFB stall...calling Roy Braatz for advice..
      clem is right go to a hobby shop for the pipe even Borg dont have it in their kit, no kit has it, it's just a mention.
      • Clem Z.
        • January 1, 2006
        • 9427
        interesting that they no longer supply the tube
        because finding it in a kit was how i learned about this fix. back then i used GM carb kits for these carbs so i guess now they figure every carb has had it done so they no longer put the tube in the kits.
