If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
Last night I was installing the front suspension components on my project car and I ran into a problem. I cannot get the bushing/nut that threads onto the lower inner shaft to engage the threads of the A-arm hole. It appears that the threads on the A-arm are messed up a bit, but I don't think this is any sort of a standard thread type. Has anyone run into this problem and does anyone have any suggestions on how to clean the threads up? The cross shaft and the bushing/nut are fine, it is just the A-arm part that is the problem.
Any help or suggestions would be greatly appreciated.
I'd reccomend taking the A-arm to a machine shop so they can re-thread. Unless you have the tools to do it properly, you could make it worse or have a problem on the road. Other option if shop can't fix, replace the A-arm. I ran into the same problem with my '55 front end. Better safe that sorry.
If you can clean them up a little as Tracy said, then start the large nuts at the same time and evenly tighten them at the same time. Now If you already have the front spring in and this is the "last" step remove the top outer a-arm large nuts and do the lower first then the top it's easier .Remember the large nuts going in to the A-arms don't TURN or say move, it's the inner thread of the large nuts that moves on the cross shaft.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
