Trying to remove the Door latching Rod from the latch inside the door.
Is there a clip or something that holds the rod into the hole to the laching mechanism.
I can't see inside and it is difficult to feel my way around in the door.
The 3 screws are removed from the end of the door that holds the Latch to the door, pulled out exterior key lock, pulled interior manual lock. Now just need to remove the rod from the hole to pull out the Latch so I can clean it properly.
The Inside door release lever doesn't have enough throw to open up the door. I have to use the exterior door handle to open the drivers side door. So I figured that I would pull the Latch and give it a good clean up in Laquer thinner and use Lithium grease to lubricate.
Thanks in advance
Thanks in advance
