If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
My clutch is grabbing very high up in the travel and I noticed that the adjustment nut is right at the end. If I turn the nut further onto the shaft will that lower the point where the clutch grabs?
thanks
It depends on which end of the travel that the nut is located. If the upper rod is now fully shortened, then I'm afraid that you've got problems.Try moving the nut and see what happens. If the engagement point begins to move the pedal downward, then make final adjustment to provide approximately 1 1/2" pedal freeplay.
If movement of the nut WORSENS the position (engagement with higher pedal), then suspect either an improper bellcrank, clutch rod, or, most likely, ball stud in the bellhousing. Your bellhousing should have the short ball stud. Many times, the long ball is improperly used.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
