1969 C3 Stingray I have my body off and have slowly been rebuild from frame up its been over a year now and I can not remember which half shaft goes to which side. I have one that is thicker in diameter then the other one.
C3 Half Shafts
Re: C3 Half Shafts
Bryan,
Are you sure?
There should not be any difference, and they should be interchangeable.
A size difference would suggest one has been replaced. I think later C3s had larger diameter half shafts.
PatrickVice-Chairman (West), Michigan Chapter NCRS
Re: C3 Half Shafts
It won't make any difference in operation, but is not 'correct' from a judging point of view. The smaller of the two sounds like an original shaft and the larger a later model service replacement.- Top
Re: C3 Half Shafts
Mike and Bryan-----
Yes, the smaller 2-1/2" OD shaft is a 63-74 style shaft. The larger is a 75-82 shaft which also became the SERVICE replacement for earlier after about 1977. They are functionally equivalent but, obviously, not the same appearance-wise.In Appreciation of John Hinckley- Top
