So Jerry - what are you looking for? A set of Moser heads? The Chevrolet prototype Trans-Am heads?
I still don't think Harry Westlake ever designed a set of SB heads, but if he did, I'd like to know more about them.
Since such heads may require different inlet and exhaust manifolds, how are you going to adapt a FI system.
BTW, the problem with the ports being "too big" will likely not be a critical issue with FI. Carbureted engines need smaller ports for higher flow velocities, so turbulence evaporates the fuel. Otherwise fuel distribution and mixture quality can be poor, even at high revs.
Since port FI systems have inherently good distribution and injection pressure causes good atomization, modern FI engines can utilize large head and manifold ports that would be unsuitable for a carbureted engine.
Atomization at idle and low speed with Rocherster FI is not as good because of very low injection pressure relative to a modern EFI system, but basically Rochester FI will keep making more power at higher revs as head flow is increased. The ultimate limitation is the air meter flow characteristics as it will eventually start to choke the engine at around 500 gross HP.
Even with just pocket ported 461s, a 30-30 cam retarded four degrees, headers and open exhaust, and the air meter tweaked to 750 CFM @ 1.5" Hg. a 327 will make about 460 gross at 7000, and head flow is the limiting factor so better heads will allow more power at higher revs until the air meter pressure drop chokes the flow.
