If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
Scott, Contrary to the other posts, I use a hardening sealer like Permatex 1A. This is for semi-permanent assembly (their term, not mine). I would particularly recommend it for plugs used in the oil gallery where higher pressures are seen.
aviation form a gasket for all sealing on every engine i ever built, oil gallery plugs,head bolt threads,gaskets and block expansion plugs and never had a problem. JMHO
I use the Permatex Aviation #3 Clem and have been doing so for a long time. I apply it with a q-tip as the brush is too messy.
I really like Loctite #545 hydraulic sealant though for many applications. I use the 545 on the fuel injection fittings and it does a nice job. Great for inlet fittings on carbs and the FI's providing you keep back about 1-1/2 threads so it doesn't wash off and get inside. Love it for vacuum line fittings. Barry Homes, our old friend, told me about the 545 20 years ago. Buy it from Travers tool since it is typically not available in auto stores. Don't know if it's good on freeze plugs because I don't work on the blocks. Have enough problems with FI's. John D.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
