Old steel wheels - NCRS Discussion Boards
Old steel wheels
  • Neil Anderson
    Old steel wheels
    I own a 62 with the origonal 5 1/2 wheels on it. I have heard that older steel wheels may have fatigued and not be safe for use with radial tires. Is there any validity to this?
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: Old steel wheels
    Not unless they have some significant pitting from rust. The steel in these wheels isn't heat treated much (if any) so side bending loads from hard cornering will not be a problem. It would bend before it breaks. If it bends, you will know about with vibration long before it becomes dangerous.
    tc
    • Dennis C.
      NCRS Past Judging Chairman
      • January 1, 1984
      • 2409
      Neil, If These Original 5 1/2" Wheels Are A Real..
      ...concern to you for safety reasons, I'd be glad to take them off your hands (yes, and I'll pay shipping) and send you whatever brand new set of wheels your heart desires.
      • Mike E.
        • February 28, 1975
        • 5134
        Re: Neil, If These Original 5 1/2" Wheels Are A Re
        Dennis-What a great guy you are! You're really into those 8080 wheels, aren't you?
          • 15610
          Years ago, probably not long after I installed Michelin X radials on my '63 in 1964 I heard stories that "radial tires overstress OE steel wheels" or something to that effect.
          I thought it was and old wives' tale then and still do.
          The same basic wheel design was used on cars much heavier than Corvette and when was the last time you heard of a OE steel wheel catastophically failing?
          You can bang steel wheels into curbs and road hazards and get them straightened. You can't do that with most aluminum wheels.
          Mild steel is a wonderfully forgiving and durable material. Its biggest enemy is corrosion, which is why there is a 25-man paint crew constantly working on the Golden Gate Bridge. They basically start at one end, go to the other over the course of several years, and then start over again - all to protect it from corrosion. Given this mainteance, its life is indefinite.
          • Neil Anderson
            Thanks for the kind offer, but as long as the whole car is origonal, I think I will stay with the origonal wheels too. Back in 67 I put the full disk hub caps on it and lost the small caps. It would be nice to get a set if you know of any. Thanks for the help.
            Neil
            • Dick W.
              • 10483
              Reverend Mike, Dennis is just being his usual generous self. And I am sure he has no real plans for the wheels other that hoarding them.
              Dick Whittington
              • Tracy C.
                • July 31, 2003
                • 2739
                Neil,
                If you don't have a problem retaining the full disk hubcaps, you probably have the 5 inch wheel rather than the 5 1/2 inch version.
                The 5 1/2 wheels have no mechanism to retain a full size hubcap and they will throw them off while cornering.
                Factors concerning fatigue tolerance apply to either.
                tc
                • Neil Anderson
                  I have had to retrieve the hub caps from the ditch a few times over the years. Believe me these are the 5 1/2" wheels as the do not have the retaining ears and they are listed on the origonal window sticker that I have, Option "276B wheels 15 X 550". I'm still looking for the small caps.
                  Neil
                  • James G.
                    • May 31, 1976
                    • 1556
                    Dennis, Dick and Mike.....you guys know how the holes get elongated with age and therefore become unsafe. These old steel wheels need to be replaced with a nice new set of American Torque Thrust D's.
                    Neil, do you have those funny brakes that squeak all the time and get wet in the rain and don't stop the car very well?
                    • Neil Anderson
                      Yes, the trials and tribulations of owning a C1.
                      • Dave F.
                        • June 30, 2004
                        • 443
                        "I'm still looking for the small caps"
                        Watch eBay. They show up from time to time. Here is a set that recently sold: http://tinyurl.com/ppxf8
                        The auction lists them as 58-61, but they are the later style 60-62 type.
                        -Dave
