1963 Hood Weather Strip - NCRS Discussion Boards
  • Ray C.
    • June 30, 2001
    • 1132
    I have read the archives on this subject and other publications including the 63-64 JG and I am a little confused. The use of 2 to 4 shaker wedges to prevent hood movement was used on early cars and deleted on the later production run. I have read that allowing the weather strip to wrap the edges of the hood prevented this from happening and was how GM solved this problem. I am ready to install the weather strip on a July 1963 SWC and want to insure I cut it correctly. What is the correct method?
    Thanks for any help!
    Ray #36314
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Alan Drake
    Re: 1963 Hood Weather Strip
    Have a Mar 64 car, no wedges and weather stripping does not wrap corner. The TIM/JM, 3rd ed, page 132 also says NO and notes later cars do wrap.
    • Mike McKown
      The aft hood wedges on the '63 hood are about 6-8 inches forward of the male latch pin. The '65-'67 hood seals are trimmed even with the latch pin on the side. The '63-'64 hood seals are trimmed to the center of the latch pin on the aft side of the hood only.
      • Mike M.
        • May 31, 1974
        • 8365
        67 hood weatherstrips are cut after they round the corners and are held in place with adhesive and a plastic mushroom rivet on each side.mike
        • Mike McKown
          Yeah, the attachment is different on the ends for '67 but the trim length is the same for '65-'67 far as I know.
          • Wayne W.
            • April 30, 1982
            • 3605
            Mike, I think you will find that the rivet is actually the metal cap ones.
            • Mike M.
              • May 31, 1974
              • 8365
              wayne: believe we're both correct, now that you've refreshed my old memory.. have seen both plastic and metal. have an example of each in our collection. regards, mike
