C1 Brake Stop Light switch spring - NCRS Discussion Boards
  • Garry Barnes
    I have disassembled my original brake stop light switch on my '56 in order to rebuild it. It is a very simple switch wtih a spring, two contacts, two washers (one brass) a button and housing that is mounted on a bracket that bolts to the steering column support. I suspect that it is the spring getting weak over time and would like to replace it. The contacts still look good. Any ideas where I might find a replacement spring or thoughts on what might be the cause of the malfunction? BTW- already tried the turn signal switch. All new and works and cancels perfectly. Thanks.
    Garry
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1 Brake Stop Light switch spring
    Try stretching the spring longer first
    • Bernard M.
      • August 31, 1994
      • 341
      Gary, Most hardware stores carry an assortment of springs. I got several individual sizes for different projects at a Tru-Value but I know that most of the other major chains also stock them.
      • Garry Barnes
        Roy,
        I bet the spring in your NOS switch would work just fine!! Good idea stretching it. I'll try it.
        Thanks.
        • Garry Barnes
          Bernard, I have a really good ACE hardware store near by. I'll see what they have. If I can't find what I need I am sure that Roy will be happy to give me his..........
          • Roy B.
            • February 1, 1975
            • 7044
            stretching it has worked for me in the past. The pic. I like showing real original parts on this forum if I can, so many people buy the wrong looking parts
            • Garry Barnes
              Thanks Roy. BTW-I always enjoy the "other stuff" that you put on here.
              Garry
