67 no raido / no heater - NCRS Discussion Boards
  • Rex T.
    • December 1, 1984
    • 455
    Just got my new toy, a 67 coupe delivered from AZ last night. Car appears to be original "No Radio" car, but someone installed a stereo in the glove box, then drilled the rear deck for a power antenna. Looks like they intended to install the antenna in the original position, then decided to move it outboard on the deck area, patching the "original location hole" they drilled. They may also have added a heater, not sure about that, but the no radio dash appears to be original. Need some help on determining if the car was born without heat and music. Naturally..........tank sticker is gone. As always, thanks in advance for your help. Rex NCRS #8089
  • Richard S.
    • November 1, 1994
    • 809
    Re: 67 no raido / no heater
    Rex,
    It might help if you posted the VIN.number, all the data on the trim tags and the engine pad assembly date and suffix code.
    • James G.
      • May 31, 1976
      • 1556
      Noland Adams Restoration guide talks about no heat, no raido cars. The ECL code on the trim tag may help also. Is this a race car Rex? You have been know to look for that stuff.
