I installed a LUK clutch in my 63 SWC 340HP project. The 63 is 99% done and I hope to test drive it as soon as the rain stops. I did drive it into the trailer and from the trailer into the alignment shop and the same process to get it home. There was no noise in the clutch system. The other night a friend and I were re-setting the valves and timing when there was a squealing sound. If the pedal clutch rod was pushed slightly to the front of the car the squeal went away. If you push the rod toward the rubber stop or inside of the car the squeal gets worse. The free play is set by the 63 manual. Any ideas of what is happening and how to fix it?
Thanks for any help!
Ray
Ray
