69 Muncie M-21 Part # - NCRS Discussion Boards
  • Wes G.
    • December 1, 1999
    • 99
    Can anyone provide me with the GM part # for my 69 Corvette 4 speed Muncie M21 (435 hp)transmission? Somehow, that section is missing from my '53 to 82 Corvette Parts & Illustration Catalog'. I would like to have 'Long Island Corvette' make a Muncie Transmission Tag, however I must provide them with the number as they specialize in 63-67 Corvettes.
    Wes NCRS # 33239
  • Mark #28455
    what was your differential gear ratio? *NM*
    • Mark #28455
      don't have my assembly manual
      But the 1973 version of the parts book lists:
      3950318 - 1969 M22
      3968012 - 1969 M22 (exc. P/Trac) Huh?
      3946798 - 1969 (close ratio w/Sp. H/Per) (427) (Exc. P/Trac.)
      3950316 - 1969 (close ratio w/P/Trac.) w/Sp. H/Per. (427)
      Hope this helps,
      Mark
        Re: don't have my assembly manual
        I think the confusion in the parts book over "P/Trac" stems from the fact that the high (numerical) axle ratios (which require a different speedo DRIVE gear on the output shaft, thus a unique transmission assembly part number) were released as ECL's under RPO G81, which was the Positraction option code. The notations don't really mean with/without Positraction - they mean with/without extreme rear axle ratios.
