Assembly manual does not show what holds the shift levers on the shifting shaft sholders. My shift levers don't have any lock washer marks. Next time someone is under their car could you have a glance at the tranny. Did the factory use a washer, lock washer, and nut? Thanks in advance.
BW T-10 shift levers
Re: BW T-10 shift levers
Richard,
Is this the attachment you're interested in?
Verne
Attached Files- Top
Richard,
I believe John answered your question more accurately. After rereading your post, I think you were referring to what I call the shift arms. Meaning the case-hardened levers that attach to the threaded shafts which protrude through the side cover and are part of the shift fork.
Verne- Top
