If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
In the process of changing front brake lines, I noticed that the fluid(DOT 3) that leaked on the floor had some "brownish" color suspended in it. Is this an indication that my system is contaminated and needs to be flushed and refilled with fresh fluid? And if I do need to flush the system, what solvent should I use?
Yes, it's probably time to refresh your brake fluid. This is not unusual. You should do this occasionally. No solvent, just bleed fresh fluid through the system. Check your master cylinder. If the fluid is cloudy there too, you might want to drain as much as you can out of there and start with a cylinder full of fresh fluid - save yourself some time.
Brake fluid is "hygroscopic". That's right, it somehow finds a way to absorb moisture, even though it's contained within a "sealed system". The brown stuff is most likely rust. The most immediate damage is wreaked on the anodized aluminum wheel cylinder pistons, which trap the moisture within the seal lands, and oxidize, causing seal failure. It's wise to change your car's brake fluid at least every three years.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
