1955 generator/transmission linkage - NCRS Discussion Boards
  • Jim B.
    • November 1, 1982
    • 10
    I was wondering if spacers were used on the generator? The bracket is larger than the two end plates of the generator.
    Also, the 55 I am restoring was an old drag car and it had a large hole in the floor where a standard transmission was put in. I have installed a transmission out of a 55 chevy car. The linkage was purchased from Grossmuellers, but the throw is all wrong. Does the small 3" linkage have to be changed? Maybe I am looking in the wrong area, can you help?
    Thanks in advance
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 1955 generator/transmission linkage
    No spacers were used , you may have a 57 bracket,about the throw, what do you mean and no the 3" is the same.
