SBC oil galley plug - NCRS Discussion Boards
SBC oil galley plug
  • Scott Marzahl
    SBC oil galley plug
    I am looking all over town for the oil galley block plug that sits in the rear of a sbc block near the oil pump. I would have thought it would have come with the new set of brass block plugs, but not so lucky. I mic'd the hole size and it's .560", Napa finally found one in their books listed at .567" which may be correct for an interfence fit, but there is only a couple in all of the Seattle area. So before I go running all over town on a Friday afternoon, does anyone else know where to find one of these or have a part number. The Chevy parts counter guy was clueless.
  • Clem Z.
    • January 1, 2006
    • 9427
    GM # 3701638 *NM*
    • Scott Marzahl
      Re: GM # 3701638
      Thanks Clem, unfortunately I just called a dealer and there computer shows that no Chevy dealer in the area has one.
      • Clem Z.
        • January 1, 2006
        • 9427
        when it is in place you can put a rod down
        thru the hole in the top of the block where the oil pressure line goes and it should stop about 8-1/4" down if the plug is in place. a dorman expansion plug catalog should be able to cross reference that number to one of theirs
