Re: A/C compressor squeel - NCRS Discussion Boards
  • Lee S.
    • September 30, 2002
    • 156
    I am very interested to hear how this turns out. I have a similar problem on a 1974 Big Block. There are various postings in the archives.
    The short version is the system was open when I purchased the car several years ago. I purchased a rebuilt Delco A6 Compressor and a rebuilt VIR. The system was cleaned out (by local Corvette oriented Chevrolet Dealer) and charged with R12.
    What turned out to be occasional belt squeal is now a major belt squeal beginning at 2,000 RPM. I have followed many suggestions but, at this time I have removed the belt. I still have the original compressor and VIR. I'm considering sending these out for as rebuild and starting all over.
    I have also noticed some continuing squeal without the AC belt. I have tried to localize the noise without success by removing other belts one at a time... AIR Pump, Alternator, Power Steering.
    As you can imagine there is a lot of noise in the engine compartment on a big block car. The clutch fan makes one helluva roar. I suspect the idler pulley may be bad as a result of over torque from the ac belt. I have a new one to install... maybe this week.
    I don't think this will solve the ac problem and have reconciled myself to another summer without AC.
    Please contact me direct if you want to compare notes.
