Questions on '72 Q-Jet - NCRS Discussion Boards
  • Mike M.
    • April 30, 2003
    • 104
    I have 2 questions about a 7042202 carb I recently purchased. It is a Carter built Q-Jet with a very early build date (G1 - July '71). The carb is for the base 350 w/ auto.
    Questions:
    1) The vacuum break control and bracket, the secondary lockout lever and the fast idle cam are all either painted or plated black. They are not discolored but are a satin black. There is some surface rust on the parts where the paint has worn. Is the black color of these parts normal for a Carter built carb, or am I looking at someone's effort to clean up the carb?
    2) The carb has a plastic choke pull off diaphram case. I have seen '72's with both the metal and the plastic cases. Was this a running change during the model year and if so, approx. when did the change over occur?
    Thanks in advance for your help.
    Mike
  • Clem Z.
    • January 1, 2006
    • 9427
    merc crusier Q jets are painted black
    so these parts may have come from a marine carb
      • 11608
      Re: Questions on '72 Q-Jet
      Mike,
      I've got one with the same date in my collection. Plastic choke pulloff and no black on those parts at all.
      Patrick
      • Clem Z.
        • January 1, 2006
        • 9427
        i have a carter built 7042202 Q jet
        with a build date D2 and it has a metal choke pull off GM# 7044903,hygrade # CPA86 as i just orderd a pull off. this is the carlisle rebuild demo carb for this year
