56 starter solenoid hangs - NCRS Discussion Boards
  • jim schultz
    I just rebuilt the solenoid for my 56 and occasionally(pretty frequently) sticks in the ring gear and doesnt return. I have to disconnect the battery to get it to stop turning over. Turning the key off doesnt stop it. There's an adjustment link on the solenoid, but I am not sure how to set it correctly, other than just randomly change it. Anyone have any experience on this problem.
  • Mike McKown
    Re: 56 starter solenoid hangs
    Sounds like the disc is arcing and sticking to the battery cable stud causing the starter to continue to run.
    • jim schultz
      I suppose it could be doing this but why, the posts and the disc was all bright and shiny when I put it together and it stuck the second time I started the car.
      • Roy B.
        • February 1, 1975
        • 7044
        Recheck your rebuilt, that the little spring was put in right, the link adjustment determines how far the gear is engaged to the flywheel , try shortening it.
        • Don B.
          • May 11, 2008
          • 132
          The starter on my '56 was just rebuilt by a local shop and the link from the solenoid to the lever is positioned on the hole furtherest from the lever pivot. I have a picture, but not sure how to insert it in this response. I don't have the problem you're experiencing.
          Don
