What is it on the back of my tach - NCRS Discussion Boards
  • Sean Conway
    I have a 1969 Corvette that I removed the Speedo/tach dash to track down any bad vac. lines. On the back off the tach is a relay? with 2 vac ports on one side and 1 vac port on the other side with 2 terminals Any help would be Great!!
    Sean
  • Michael M.
    • April 1, 2002
    • 149
    Re: What is it on the back of my tach
    Vacumn relay for wiper door.
    • Dick W.
      • 10483
      This slolenoid sends the vacuum signal to open the wiper door. When you turn the wiper switch on, the solenoid opens up and lets vaccum flow to the relay valve, which then opens and lets vacuum flow to the cannister on the firewall.
      And they said Rube Goldberg was dead by 1969
      Dick Whittington
      • Michael M.
        • April 1, 2002
        • 149
        Basocally an electrical switch that opens "Allows" vacumn to the wiper door actuator. One of the vacumn connectors is a vent - so no hose gets attached to it.
        • Chuck G.
          • May 31, 1982
          • 2029
          It's technically called the "tach solenoid". Chuck
