C3 Exterior Door Handle - NCRS Discussion Boards
  • john t wilson
    How well do the current GM replacement exterior door handles fit/compare to orginial?
    My passenger handle broke and I want to replace both because the driver side is pitted. I have seen the GM handles for about $75 each.
  • Michael W.
    • April 1, 1997
    • 4290
    Re: C3 Exterior Door Handle
    There's basically two types of repo handles available right now- a higher price unit that comes in a GM box and a lower price one (around $30.00) that's only good for the lower end of a plumb bob.
    Yours might be the higher price one and is the best your going to do.
    • Harmon C.
      • August 31, 1994
      • 3228
      Mike
      I have used both and the GM quality was one good and one the handle hung up from day one. I will pay the $20. for the repo. as they have all worked good for me. They all will take a hit from some judges.
      Lyle
      Lyle
      • Dick W.
        • 10483
        Lyle, I think that there are at least two reproduction handles besides the GM one. One is of very poor quality and the other is somewhat acceptable. I do not know who makes either nor do I know who is importing them.
        Dick Whittington
        • Harmon C.
          • August 31, 1994
          • 3228
          Dick
          Tom Keen had them made at least 5 years ago and I found them to be OK for service. Yogi had a display door with a handle at Bloomington this year so he may also be having them made.
          Lyle
          Lyle
          • john t wilson
            Can my orginial door handle be welded. Mine broke on the bottom side which would not show if repaired . The parts fell inside the door and I was able to locate them. I just need a pic of the orintation of the springthat keeps tension on the lever that moves the door latch. ( I have on ideal what it called)
            • Michael W.
              • April 1, 1997
              • 4290
              The low cost ones that I alluded to above have a very weak mechanism underneath. Typically, when it fails your door is jammed shut and you have to find the copy of the Restorer with Tom Russo's article on how to get it open again.
              • Dick W.
                • 10483
                Tom and Yogi's seem to be ok, but there is a very poor quality repro ou there also
                Dick Whittington
                • Chas Henderson #28127
                  Think I would start looking for a used one, after reading all the above.
                  Chasman
                  • Michael W.
                    • April 1, 1997
                    • 4290
                    I have a pair of used el-cheapos you can have for free. One is presently used for a plumb bob, the other as a door stop for the shop.
                    Both have been smacked with a hammer to teach them a lesson.
