Points of attachment for a 66 grille - NCRS Discussion Boards
  • Dennis B.
    • May 31, 2004
    • 174
    My 66 Coupe is in for paint and the grille is out. It will go back in in a few days. Since I have owned the car it has only been atttached using the two ourward brackets. I have purchased the center upper support rod so that gives me three points of attachment. One more. The lower center attachment of the grille is attached how to the car?
    Dennis #41966
  • Dick W.
    • 10483
    Re: Points of attachment for a 66 grille
    There is a post previously that may help you.
    //https://www.ncrs.org/forum/tech.cgi/frames/review/238182]https://www.ncrs.org/forum/tech.cgi/frames/review/238182]//https://www.ncrs.org/forum/tech.cgi/frames/review/238182[/URL][/URL]
    Dick Whittington
    • Dennis B.
      • May 31, 2004
      • 174
      Thanks Dick but that link does not work for me.
      • Reba Whittington
        Oops! One too many //'s. Try this one
        • Reba Whittington
          One more time. I am on Reba's computer now. For some reason mine will not let me link to this post. Probably because it is way past this old man's bedtime
          • Dennis B.
            • May 31, 2004
            • 174
            Thanks Dick. My car has been damaged in the front years ago. I still have the upper fiberglass tab under the nose but the bottom one is gone now. However the center support rod for the grille was also missing along with the headlight motor support on the driverside. So at least at this time those will be put back in. Found those at Paragon.
            Dennis #41966
            • Dave K.
              • November 1, 1999
              • 951
              Dennis,
              I believe that the early 66's did not have a center support rod. Center rod was added in later 66 and is on all 67's.
              Dave K.
              • Dennis B.
                • May 31, 2004
                • 174
                Dave,
                This is my understanding. According to Nolan Adams resto guide a mid year change for the center support rod occured at #114333. My car is #115451. Sooooooo I assume mine would have had the center support rod.
                Dennis
