heater coolant flow - NCRS Discussion Boards
heater coolant flow
  • Mark H.
    • July 31, 1998
    • 384
    heater coolant flow
    which direction does the coolant flow through the radiator core ('64)? in the top and out the bottom?
  • Dick W.
    • 10483
    Re: heater coolant flow
    Flows through the engine, out the top hose, into the core and back into the engine through the water pump.
    Dick Whittington
      And coolant flows out of the intake manifold through the 5/8" hose to the lower heater core nipple, through the heater core, then out through the upper nipple and 3/4" hose to the fitting on the water pump.
      • David L.
        • December 1, 1981
        • 116
        John,
        Is this as true for the '58 configuration? I'm ready to hook up my heater hoses after 24 years. Thanks for the help!
        David
          David -
          Not quite - 58's used 5/8" hoses for both the supply and return hoses; the 3/4" hose for the return line didn't start until 1959.
          • David L.
            • December 1, 1981
            • 116
            Thanks John! I'll check my hoses to make sure they both are 5/8's and connect them as per your description in the post above.
            David
