Several questions pertaining to the installation of the dash and wiring harness.
-Under the dash, drivers side, there is a cross member/brace bar? there is a hole above the steering column bracket, what goes thru there? Oil pressure line?
-Also, on the right side of the steering column bracket is the emergency brake bracket with a hole on top - what goes thru there?
-The condensor that attaches to the ammeter, how does it attach to the clip? The condensor has a brass connection (V) shape, it does not fit into the black ammeter connector?
-Cigarette lighter, the wiring diagram show a solid red wire connecting to the back of the lighter. It also shows a black wire attached to the top of the lighter? Where does it clip on to?
As you can see, I am not an expert in the electronic diagrams, hopefully I will be able to connect all and get this baby on the road!
